96 GTX magnito plug
Black67tb
Hello. I have a problem. Looking inside the magnito plug, l see only 5 prongs. I see 6 wires on the back. Is one broken off and missing? If there should be 6 prongs instead of 5, is there a way for me to repair the plug somehow? I would appreciate any feedback. Thanks.
I'm pretty sure you have 3 yellow wires on top and a single yellow and single black wire on the bottom. The 3 yellow goto the Magnito and the single yellow/black goto the pick up coil. I think there is a light gray plug in that 6th hole.
I took a better picture of the back. As you can see, three top wires are yellow. But on the other side of THOSE, there are only 2 prongs. The other lower 3 wires, one black and one white go to the pick up. The other black, l suppose goes to the stator plate for ground. There are 3 prongs on the other side of these wires.IMG_20220316_135846.jpg
Here is the wiring diagram. Looks like the Black/Yellow and Black both go to ground. Up to you what you do with it. :) Probably doesn't matter unless it matters. LOL
Thanks for the schematic! Now l see! There needs to be 3 prongs behind those 3 yellow wires. One is broken off. Is it easy to take that plug apart?
