Ardilla
Hi,
I rebuild the carbs of my 787 96 GTX with Mikuni kits included needles. Now throttle response is good with no issues or any strange hesitation and starting is fine. Fuel line is directly connected to full buttle on reserve to avoid any issue from this side. Ski is stock. I also cleaned the RAVE valve and water regulator.
The problem is that the ski has no power, I can push throttle WOT but ski is not accelerating and has no power. Max rpm once starting are 6800-7000 rpms but ski is not moving strongly. Max speed is really low and it take a lot to take off.
I check the wearing and impeller as I change it couples if year ago and they both look totally new. I moved the drive shaft manually, but it is totally free and moving smoothly.
Thanks for the support as I do not know where to go now… Engine can be wrong? reaching max RPMs?
Thank for help
Frederic
Thank for help
Frederic
