Rock Creek Rider
96 GTI running stong again after cleaning out carbs and replacing gray fuel line thanks to advice from this forum! THANKS GUYS
This weekend during all the heavy 4th boating traffic, the 3 bolts/1 nut holding the toned pipe assembly had all vibrated loose off the exhaust manifold!
After bolting and torquing it back down all seems to be well with the exception i noticed a pinhole size leak in the metal area betweek the top 90 degree elbow fitting and the lower elbow fitting - right in the middle where there is a circular weld.
Questions: (1) Are there issues that I need to be aware of that caused the toned pipe assembly bolts to vibrate off the manifold? (2) Can I just patch the pinhole leak in the tuned pipe? Was internal rust the culprit here?
