As a new member and a hit or miss fix-it type I am all ears for suggestions about how i might solve this problem. After last ride in October, I did the usual startup to clear water from exhaust. The engine kept on accelerating even though the throttle cable was not stuck. I was barely able to shut 'er down. Every time I try to start it (to winterize) the same thing happens. Any suggestions? Friend said it could be a vacuum leak. A dealer i called said that gas lines should be changed. I would love to solve problem myself if possible but it is also 22 degrees in Philly as I write.
Also, hope to tow ski to Florida for a week in March. Can a 99 toyota Sienna be fitted with a hitch and handle the tow with a loaded van?
