96 gsx
Da/man
bottemed out, after that wouldnt rev up but stayed idleing fine. also added sea foam, is lots of white smoke normal..
I ran slow through some mudd.. also long continous beep came on after that, is the white smoke bad??
just checked down under.. just a little sea weed... cranked it for a sec and it sounded great, maybe i need to clean the carbs...
Is it white smoke or is it steam. Running thru mud you may have clogged the cooling system and the continuose beep would be the over heat buzzer. Did the buzzer shut off after idling for a minute? You may need to clean your cooling lines out, but first i would run it on the hose and see if water is comming out the pisser! Start ski, turn on hose see if you have water coming out then shut off hose turn off ski is the proper steps. If you turn off the ski with the hose running it will fill the engine with water and thats really bad.
fixing to go try to flush cooling system, but definatly smoke, can smell the fuel strong in the smoke...
Cooling lines
do you have a flush kit for your ski and yes seaweed can clog your cooling lines which can make the engine burn hotter and eventually cause engine damage if not cleaned out.
