96 gsx wont double beep, silent
hackdaddy
hi, had a great weekend skiing until the last hour of the day. my daughter dumped the ski and we went threw the usual draining issues.
i'm getting no "double beep" when i hook up key, charged battery over night and nothing... when we got home from the lake it would double beep then just click...now it does nothing.....
where are the fuses located, specifically is there a fuse from ignition switch to starter ?
help, it's 90 degrees and i wanna ski.....
thanks for any reply !!!
Be sure the battery is fully charged and has fluid in it...if the fluids low it won't have enoughs amps to start the seadoo. Check the ground- wire going to the engine by the starter. If it isn't getting a good connection it could be your problem.
Let us know how you make out.
Karl
Check the ignition box - the black one that the spark plug wires run to:
If water infiltrated the box (possible during the roll if the rubber gasket to the lid is a bit leaky, then the water might be causing a short or corrosion.
no beep beep having anything to do with solenoid
dealer says so, i've arc between two screws on solenoid and silent do i need key on etc. it beeped yesterday today no beep with key on.....
