cam2rich
Tried to test out my GSX last weekend and things weren't going to hot. Ski wasn't running well so I kept having to restart it and lay on the starter. After a while of starting, running, waiting, etc. it did something strange. I hit the start button and let off and I could here just an electric motor going. I'm guessing it was the starter motor spinning but not firing/engaging. It kept going after tapping the start stop a few times and removing the key, so I had to disconnect the battery after probably 2 minutes. When I reconnected the battery, the start button did nothing but I did get my 2 chirps with the key. Here I am a few days later, I charged the battery and went to hook it back up and the starter immediately turns over the engine. I tested the start button and the ohms on the rd/yl wire at the aftermarket mpem, and both were good. If I disconnect the plug on the solenoid, the starter doesn't kicked on. Metered the plug and it's getting 12v. Disconnected hot from the starter and connected the battery and you can here the relay in the solenoid fire. I'm at a loss. Both the mpem and solenoid are new. Assuming the plug at the solenoid should have power as soon as the battery is connected. Any tips?
