fastfive_ogt
Hey guys I have a 96 GSX and it has the two beeps when you put the tether in and I checked the fuses in the grey box up front(good). It has no spark. I tried that mpem diag thing with hitting the start button 5 times and when I do that it gives a short and long beep. What wires do I check for the coil primary and what should I see there? Also if it beeps twice when I put the tether on mpem should be good right? It just wouldn't start one day, shortly after rolling it over in the water. Can I ohm the stator? If so what are the specs I should see? How about checking the output of the stator while cranking? What wires would I check to do that? Also then I should be seeing an AC voltage correct? I am an auto technician for a ford dealer so my mechanical and electrical knowledge is pretty advanced. Still hard to diag a pwc when you have no schematics or any idea what you should have where to find the missing peice of the puzzle. Thanks in advance for any help given.
