I Drink Alone
My carb filters clogged up about every year and a half, so based on advise from this forum I took them out and put in a replaceable in-line filter just before the MAG carb and replaced all the fuel lines. Doo ran great 1st couple times out, probably 3 or 4 hours. Then it started great but began bogging down on accel. Starts good, idles good, runs up to about 4000rpm if I throttle slowly and gets on plane, but more throttle than that and it actually slows down. It did this for about 7 or 8 mins. then was okay. Ran for 30-40 mins. wide open, donuts, the works, and then began bogging again. Cold, warm, choked, unchoked, no matter it does the same now and won't come out of it.
Rechecked all hose clamps, rechecked RAVE diaphragms. Everything fine but seems to be about when the RAVE's should be opening and it gets a dramatic loss of power; never dies just sounds like it wants to and will run all day at 4000. Plugs were new when I did the other work and are now slightly dark but clean. Compression about 140. Would anything electronic do this or do I need to tear the carbs down further?
