96 challenger
brian lewis087
800 single motor I get two beeps like for the start up and then I get four short beeps .. would that mean that the CDI box is bad
Don't know if your boat is same, but 4 short beeps on my boat means the shifter is not in neutral.
Hope this helps.
I agree. Shifter code. And I have seen this is the neutral safety switch is bad. It THINKS it is in gear.
ty that was the problem,, now I have a new one . I bought a new battery and a new selinoild . motor will not turn over. I get a click from the seliniod when I push the button , I have lights and the gauges, but no nav. lights or blower fan
im about to invite my friends over for a barn fire
Ok.. Lets break this down a bit.. First, lets see if it will crank. Jump the solenoid, does it crank or not? I could go into details but lets get this answer first...
The other issues may be as simple as you have the additional hot wires on the wrong side of the solenoid. The battery wire and ALL ADDITIONAL hot wires go on one side. In fact, normally one of the additional wires is what feeds the MPEM, which ultimately controls the solenoid.
I tried to jump the soliniod with a screwdriver and nothing .I took a battery pack and hooked it up to the starter side and it turned over.. I do have the two hot wires on the battery side , hot for the mpem and the other is a 20 amp fuse. I do know that u have to have constaint power to the mpem
Ok,, bottom line is,,, if the wires are correct you have a junk battery, bad wire, or poor connection. But I am going to bet something is hooked up wrong as it worked before... (Right? it did work before, yes?).
You need a single large wire from the battery to the solenoid. And on that same terminal you will need all the other accessory hot wires, (normally the MPEM for example). On the other large terminal you will have ONE SINGLE wire running down to the starter. If it is hooked up like this and you jump the solenoid and nothing happens, then junk battery, bad cable, bad connection...
Your front fuse box is under your storage bin in the front. There is another small fuse box there that runs all the accessories. Front Nav light could also be corroded through. It runs a funky light bulb that costs money.
My research suggesting replacing the front light assembly with this:
Attwood 3500 Series 1 light ~30.00 It is also LED I think.
Your blower could be shot. Mine was. If so, replace with new one.
Ref P/N 278000538 (seadoo).
Atwood Turbo 4000 Series II ~24.00 on ebay
Hope that helps.
