DeltaCruiser
Purchased a 96 SeaDoo Challenger, and we are having problems with starting the engine. Our starting sequence is: Insert lanyard (2 beeps), wait about 30 seconds (click will be heard from mpem when the rear cover is open), depress start button. (According to the manual, we should hear 1 beep to signal gear is in neutral, but we do not). The boat started a few times, but will no longer start. The engine will turn over using a jumper wire from the solenoid. Should it actually start using this method? Battery, fuses, wires checked. Start button checked out. Lanyard read .5ohms. What are we missing and what should we check next? Thanks.
