This started two weeks ago.
The engine works fine "once in a while". But after I run it and pull back to idle, when I try to accelerate, it won't go past the 4100 rpm mark. It's like that "over-drive" never kicks in to get it up on plane.
I put some water eater stuff in it yesterday, thinking that may be the problem. I have about 5 gallons of gas left in there. Also, cleaned the fuel filter. Worked fine when I first pulled away, but once I pulled the throttle back, I couldn't get it past the 4100 mark again.
I also have something goofy going on with my key. I posted previously about. Sometimes it works and other times I have to hit the start button without the key, then put the key on to get it to start. Also, the double "beep" is barely audible anymore. ...Not sure if everything may be related?
I appreciate any input...Thank You!
