68ragtop
According to the Manual, The crank pin should have a beveled edge that installs towards the CB. What I found was both ends of the pin are the same. very outer edge is beveled. However, it does have a groove on one end that is not mention in the manual. Anyone know what way this is suppose to go in? If I installed it based on the wear marks from the bearing, the groove would go "away" from the CB shaft. But, there has been nothing about this engine during teardown that would make me believe it was installed correctly. Is this a superseded part?
