This ex has set for two years I most have forgot to winterize. Just put new battery and it would not crank. Took out plugs and they seem to spit water and oil. How do I find what is broken. Thanks
What seems funny is if it is water there was a lot still tere for two years if it is water there is a lot of oil. Took off the water lines that go to the head and they are dry
If it is seized it needs major repairs...if it spits oil and water it must be turning over...but it might still be junk. Do a compression test if it turns over.
there are 2 seals in the middle of the crankshaft. they weep a little oil usually. they have had 2 years to weep. you have probably blown most of it out by now. pour a little gas in cyls. crank it some more. it will come out.
