95 xp problem running
surforguy
Hi all, first time posting. These are great forums, I have been reading them a lot finding some good info.
I have a 95 xp 720. I had not run the ski in a while and I took it to a shop to have them fix it up and get it running for the season. I had them take off the oil injector to just run pre-mix as well. When I started it up out of the water it fired right up and seemed to run fine.
When I put the ski in the water it didn't run so well. For about 3 mins it seemed good as new running fine, then all of a sudden I couldn't get it to go over a slow crawl. It acted like it would not rev up or it wasn't getting gas. After a min or two it just died, then couldn't get it running in the water.
It does have the gray fuel lines which I will be changing out. I believe they are 6mm from checking the parts inspector. Is this correct?
I am not sure what else it could be. I am going to double check that they did everything correctly when removing the oil injector.
I am not very mechanically inclined so the more detail the better. Thank you very much for the help.
Feul selector
I know this is going to sound crazy but did you switch from on to res for your fuel selector. You may have some build but in there.
Thank you for the tips. I will replace the fuel lines and try to figure out how to clean the carb. Like I said I have no idea what I am doing.
I am pretty sure I had the fuel tank set to on.
lol.
