the starter recently went out on my 95 xp, so i have it torn all apart since i have some other work to do to it over the winter, but when i took out the starter it had quite a bit of oil in it, and when i took the cover off the starter fly wheel case (not sure what its called exactly), and there was some oil in it as well. so my question is should this be bone dry in there or do i have some sort of crank shaft bearing or seal go bad. i don't want to just put the new starter in if it will just happen again
thank you
thank you
