Hi All,
I have a 95 XP with a Factory Pipe that I just recently purchased, After a bit of work I got it up and running and seems to run really well...with the exception that about every couple of hours of run time it fouls out the plugs!
We have to go through about a 5 min no wake zone and it seems to be loading up during that time.
Here's the work done so far:
Replaced gray fuel lines, cleaned out all filters, cleaned gunk out of, and rebuilt carbs, using existing jets and the same color springs, so I'm taking the previous owners word that the ski never fouled plugs when he had it, so am assuming the carbs were set up right before! ( I know...I know), I have the low and High mixture screws set to the specs at factory's website, Which are
High speed screw : 1/4 turn out from closed
Low speed screw : 1 turn out from closed
So my question is what can I safely try, to stop it from fouling these plugs out all the time? I was going to try turning in the low speed screws in a quarter turn but wanted to run it by you Guru's first, as I know that running it to lean can be really bad, but I was also informed that the leaning out the low end is not as detrimental as having it running lean on the top end...is this right? Also can anyone tell me what spark plugs are the right ones? It had NGK ME8* or something like that...is this the right one? If so can I go with a Hotter plug? If so, what number would be recommended?
Thanks in advance for any advice you all can give!
Mike
Mike
