vallentinerocks
Ski had been sitting for many months by previous owner outside in winter. Heres what I have done:
-rebuilt and cleaned both carbs
-cleaned fuel filter
-changed stock grey fuel lines with new black fuel line
-removed and cleaned fuel selector
-replaced fuel float with new one (missing magnets and no gauge operation) works now
-new NGK spark plugs and wires
-added see thru fuel filter before carbs
-fresh gas (4 gallons) and Stabil Marine
-new battery
Checked spark- both have decent spark it appears. Compression check both cylinders right around 126psi, kinda low but even. ski does have leaking crank seals and/or rv seal as oil has come out exhaust and has been sitting for atleast 9 or 10 months. Carbs are at 1.5 on low speed adjust and slightly over 0 on high speed adjust. Have no idea what its idle RPMs are right now in garage.
so it starts up smoothly, and idles. have only been running it for 10-15 seconds at a time and stopping it as its in my garage. I have not ran in out in water yet or WOT. At first the throttle responds normal, but eventually after a few starts, it fouls the MAG side plug, and when its too wet, the ski will cut out and die, wont throttle up. I can pull the fouled plug, dry it, put it back it and it runs fine until it fouls up again.
wondering if its times to take it down to the water with extra plugs, and run it in the water for a few, just to maybe get all the oil that maybe fouling that plug... then maybe i can have someone try to tune the carbs. My next Step??????
-new battery
