I have a 95 XP that it seems the needle bearing was not greased, when cranking the engine, the rubber boot, between the drive shaft and through hull fitting, twists. One I got the engine started the plastic through hull fitting smoked and started to melt, I shut off engine and have new bearing to replace, does this seem to be the only problem? or is through hull fitting easy to replace to? Thanks
