this ski runs great and has no issues until its used for a while. It had an idling problem, but I set the throttle up a little and it went away for a while...then after it warmed up it had issues again...would drop below 1000 rpm and then slowly die unless you tapped the throttle. Then I was at full throttle, running good and it died...completely and fast. No warning lights, so I restarted and it was fine for 30 seconds...then died same way. Started and ran for 15 seconds, all at full throttle, then died......I'm afraid to restart now. I immediately thought it was an overheat problem, I may have heard an alarm but at full throttle its hard to tell. Anyone know if I have an alarm? Could it be a clog in the water intake? I am told if its an oil injection problem it would have failed catastophically. Any ideas are appreciated.
PS this ski had an engine compartment full of water last year when it almost sank...Seadoo dealer re-worked the engine and its been fine till now.
