I am new to jet skis, but have been looking around and reading the manual. I am still lost on these 2 stroke engines and rotary value stuff.
Engine ran when I got it, but any time you put it in water it seems it would bog down and die. Then be hard to restart.
figured it was a carb issue, so I rebuilt the carbs. Cleaned parts and found clogged pilot jets and such. The Pop off pressure was also wrong.
Took a while to get it all dialed in, but it started and seemed to be doing better. once started it would stop/ start just fine out of water on the hose adapter (stopping water flow when engine was off). Took it to the lake and got it to start one time and idled a bit then died.
Tested the battery, and it was swelling after the charge so I bought a new battery and rented a compression tester.
I followed the instructions on here:
1) remove plug boots and put on grounding post
2) remove both spark plugs.
3) install compression tester in 1 cylinder at a time
4) with WOT press start button and keep going until you see max PSI
5) repeat 3 times
6) move tester to other cylinder and repeat 4 & 5
I got 60 PSI in the front (MAG) and 28 in the rear.
I know thats extremely low, so my questions are:
1) Besides internal damage is there anything to cause low compression? IE rotary valve timing off etc
2) is it possible for these things to run on such low compression?
the first time I took it to the lake it had issues idling (before the carb rebuild) but I got it out there and at higher RPMs it ran great and would hit WOT and while no speedo I have little doubt it did 40-45 MPH. this does not seem like it would be possible with the low compression I just took?
thanks for any and all help.
5) repeat 3 times
