95 xp 720
sloan smith
bought a rebuilt dual carb, rebuilt the old one and still this ski want get out of the water. runs better with the new carbs dosn.t backfire out the first carb anymore but under a load in the water this ski want get up. Someone told me it could be the reeds. can anyone out their give me a clue to what is going on. thanks sloan
Welcome to the seadoo forum Sloan. Are the carbs adjisted properly? Did you tune them after it was in the water? The carbs must be in sync with each other to be able to perform properly. It might also be the Reeds in the Reed valve assy., that need replacing. Do you have a seadoo service manual? The sync proceedure is a little too detailed to post it in the forum. If you want you could join as a "premium member". As a premium member you can down load a authentic seadoo manual from the seadoo manual library. In the library is a variety of manuals for almost all years and models. You can view as many as you like on line as a PDF file, or download it and print it for your personal and privet use. There are operator manuals and repair manuals for you to do your own repairs on your seadoo. The repair manuals have everything from troubleshooting, repair procedures to winterizing. It contains wire diagrams torque specs and pictures for disassemble and assemble instructions. In the spec sheets it tells everything needed to maintain oil changes, spark plug gaps, carburetor rebuilds and impeller wear ring tolerances. Click on the "Seadoo Manuals" link at the top of the page for more details. If you need any help or get in a jam, we are always here to answer your questions too.
Karl
