'95 spx ignition problem
ckaz613
No spark to plugs. Checked voltage to ignition coil. Only getting 1.5 to 2.5 volts to coil from ?m?p?eg thing..(control board). What should it be? Or do I have a fried board? Thanks for all your help:cheers:
alright, disconnect it, from the butt connector, and give a try. If it fires up, you'll need to choke it, to kill it. If this is the case, then you'll need a new mpem, or switch is bad.
Thanks. I tried and i am still not getting any spark. sorry for all the ?'s, but I just don't know what to try next. thanks for all your help!:cheers:
