rags
Hi all new here, Just bought sight unseen 95 Sportster trailer tarp. $1100 Cdn so figured good project good price. Now sits in yard and sunny so figured Id try and figure out what it wont start. Owner said worked fine for a few years sat last two years now wont start.
Im not new to mechanics and projects but Im new to Seadoos. So ive done some quck trouble shooting and got myself to a point where starter fires engine wont turn.
The problem does not start......ok I did lots of trouble shooting and am now at point where I can get power to starter and drive gear fired out hits fly wheel and wont turn it. Good solid clunk so it drives out and gets in the gear just wont turn it. So what i figure is either 1 of 3 things or all three lol.
1 - Pistons seized in cylinders
2 - out put shaft bearing seized
3 - jet pump propeller seized
First could be seized pistons Ive added oil and varsol mix to piston chamber to lube and loosen rust corrosion if any. I will let the set in for now
Second out put shaft bearing greased and ready to do some test to see if it turns whats best way to test the complete out put system to see if its 12or3? Is there a quick check to turn shaft and or disconnect a part to best isolate the 3 items i listed so I can better pin point problem area? Do I just get a pipe wrench on it and try to turn to loosen it if partially seized? which does it turn I assume clockwise?
Third jet pump I will change up oil and clean around it but dont have an alignment shaft so hesitant about just pulling it off and apart and cleaning it then put back on.
Thoughts on quick check rather then pull entire PTO system from fly wheel to jet pump off.
Rags
Thanks
Rags
Thanks
