achtungbabi
HI Everyone, Thanks for all the advice of late re the Speedster. Im very happy to say with a little love ( did the crank test and the battery boost) the starboard engine kicked over and then into life with a whole lot of smoke, spluttering crap and all sorts of garbage out of the exhaust. let it run for alittle bit to clean it out and the revs came down and it began to purr. It will now start first time without the battery booster. Very happy.
THe port engine was then given the same treatment, removed plugs and crank test.) SLowly it began to crank. slowly the fuel moved through the lines and closer it got. Till Finally with a big crank it started and ran for a few seconds. Unfortunately by this stage the batteries were both starting to get low. and are now on the charger over night to have another try tommorow.
IM wondering now is there anyway of having this engines start more easily. Especially the port engine. or is this something i will need to put up with
In the next few days, fuel filters will be replaced. Spark Plugs and newer fuel will be added. im also going to try and clean the plug leads and see if that helps.
But are there any other ideas.
