So my dad bought this boat new back in ‘95 (657x engines). I have now acquired it from my uncle who had it for a few years also. So my problem is that the port (left) engine will run great for about 5-10 minutes and then just shut off. No sputter, no misfire, just gone. It’s also hard to restart until it cools off. So the backstory is when I got the boat I had to do a top end on the left engine because it gaulded the front piston. He knocked an oil line off while changing batteries and didn’t know it, crank looked good and rods didn’t have excessive play so I put a set of std pistons back in it and honed the cylinders. Engine also didn’t have any spark (before the rebuild) so I replaced the coil with a Chinese unit. Also replaced the one mpem with dual mpem’s since the port mpem fuse was blowing.
So to summarize how this has gone, Stbd engine is fine, port engine didn’t run, replaced coil for port engine and both mpem’s, port engine runs for 10 minutes and dies no warning, rebuilt port engine because of low compression, with the new top end compression is now 150, port engine still dies after 10 minutes. Spark plugs were new but are now chocolate brown so it’s not lean or a fuel problem (I don’t think) Just put two new props in it because of cavitation and was hoping that was causing overheating. Apparently that wasn’t it but it needed it anyway. So now I’m thinking it’s the Chinese coil unless someone can give me any more suggestions.
