Hey all, first time posting. I bought a 95 speedster this past October as a winter project. It was half taken apart but mostly all there.
My motors were both full of oil when I bought it. I did a lot of research on this problem, and I've tested both the crankshaft seals on both engines for leaks. They both held 5psi for 15min no problem.
What I did notice is that the oil pumps (I assume that's what they are, the part that bolts between the carbs and block where the oil is injected) leak out of the injection ports when they're sitting.
I had them both disconnected from the engines and sitting next to them but still connected to the oil reservoir, and oil would drip out of the oil injection nozzles overnight. The engines when left connected to the oil supply did not fill up.
From my research this doesn't seem to be a common problem, as it seems to always be the crank seals or rotary valve seals. But those test fine.
Is there supposed to be a check valve or something to stop oil from constantly dripping unto the engine? My other thought was that since both throttle cables were disconnected when I bought it, the oil pump thought that the motor was under throttle and was allowing oil to flow. Is that possible?
Sorry for the long-winded first post, but I wanted to let you know that I've done my research on this and am stumped. Any thoughts? Thanks!
