95 seadoo xp
I have an 95 xp. What part is it when... when it's stored I get too much oil into the bottom of the motor. I'm still useing the oil pump not premixing. I tried crimping the lower gravity fed hose from the injector tank. Not crimped when I'm trying starting it. I pull the plugs and turn it over not much oil comes out of the holes. I charge the battrey up and clean oil off the plugs.It then starts. Runs rough for a min.lot's of smoke then seem's o.k.. Does this mean the motor will need to be torn apart? (crank shaft seals)? Should I get through this summer rideing it by. Premix 40-1 remove to oil pump shaft. Put the lower and upper hose going to the injector tank Together with i radiotor flush kit. Untill I'm ready to tear it apart.
yeah, sounds ur inner seals are shot. You can get away with ride'n, but eventually, need new assy. Dont "loop" the system, cuz, it'll still bleed into the motor, and then what...no more oil..BOOM, so keep it hookedto tank, crimp lines when not using and keep fill'n rez up...
