Before I stumbled upon this website which seems to be informative.
A couple of weeks ago my son picked up a 95 XP 720 after a river run with the brother in law on a impulse buy.
The ski is kinda dull and faded looking. The plastic is faded on the top side. The seat needs a new cover as it has damage from cats claws. The bottom of the ski has some scratches, chips but looks to be repairable to me. Looks to be 100% intact and original.
The ski cranks over with no unusual noises, has spark in both cylinders, the vts is functional, looks like the prop is ok but the wear ring looks to be scored from small gravel or sand, guages are functional.
The XP was purchased with a single trailer from my daughters friends father....Got it on the cheap and figure the trailer is worth half of the purchasing price.
He stated the lower end was rebuilt. He said that at one time the ski was run without the water hose hooked up by a bone head and fried a piston. He stated the upper end was also gone thru afterwards. He said last time he took it to the lake it ran great for 10 minutes or so and then it died out. He stated he couldn't get it running and it almost runs with starter fluid but won't kick over. He thought rotary valve timing was off.
I pulled the motor out of the ski as it's too tight to work on the rotary valve cover for me at least. Figured it would be a learning experience if nothing else anyways.
Two of the bolt holes for the rotary valve cover were stripped so I just heli-coiled them which worked out fine. Just put the cover on temp as need to get gaskets and new bolts....Held off on ordering parts as I found another issue.
Once the engine was out I noticed one of the head bolts on the pto side wasn't all the way down so I tried to tighten it up. It screwed down in but kept spinning. I tried to remove it but it came up a little bit and wound up haveing to pull it out with pliers as it was broken off. It looks like it was just coated with clear silicone and pushed back in place. I removed the cylinder head to get a better look at it. The mag side of the head is beat up pretty bad but cylinder and pistons looked newer and are marked 0.50 so I'm thinking that they have been replaced as stated.
The pto jug looks to be unsavable it looks like the bolt was either cross threaded back in or reinstalled without cleaning up the threads on the bolt and in the hole first. It's cracked along the protruding part the bolt threads into. I thought I'd try to get the bolt out to see but it's a no go on it. Drilled out center, soaked with liquid wrench, heated, tried easy out which snapped off after barely budging the bolt. Got easy out back out soaked and heated more then tried rotating the bolt with a punch but crack spread further so decided it's a waste of time to try any further.
Googled and found this website after a little bit of searching!
Looking around the site I stumbled onto the grey fuel line post which was informative. Figured I'd take a look at the carbs and fuel lines as I didn't smell any hint of gas when I was cranking the ski over before I yanked the motor out. I figured it was time as it's easy to get to the carbs with the ski apart. The mag side carb filter was pretty plugged up so I cleaned the screen and passages out with brake parts cleaner. The pto carb was plugged up really bad so did the same but had to use a small pick also to get the inside of the filter cleaned out. The carbs looked to have never been messed with as the paint was all intact so I just put back together with the original seals for now. I figure that the ski sat for a while the lines went bad and the last time the owner took it out the carbs got plugged up on him.
Currently I'm debating if it's worth putting money into it or just parting out the ski and keeping the trailer.
I figure I'd need the following items at least.
A new pto jug
Most likely an upper end rebuild.
Gaskets for intake, exhaust, head
Possible head as one dome is beat up pretty good it looks like.
Fuel lines
Spark plugs
Who knows beyond here.
Parts don't look to be too cheap for these and some of them look to go for more than I'm into the ski anyways.
Thanks in advance for any adise you may have!
A new pto jug
Fuel lines
Spark plugs
