I need help please. I have a 1995 seadoo GTX 657cc I believe. It sat for about two years before I bought it. It won't run with the fuel switch to on but runs fine on reserve? It does have the gray fuel hose so I guess I need to change it and that should probably fix my fuel problems? Also, my red battery and low fuel lights are on all of the time while it is running. I put a new battery in and it shows 13.8 vdc while running and 12.8 while not. I assume it is charging correctly. Also, upon initial startup, the led bulb check lights the fuel gauge completely black for a split second then nothing. My fuel gauge reads nothing but the info center shows a red light irregardless of the fuel in the tank. I am curious if its the info center due to two lights on at the same time or could it be a common ground issue? Please advise if you have any ideas about this. Thanks in advance.
