accidentprone369
I'll try to keep this short. Last year we took the skis out, the battery on one died and the hull filled with water during towing. The engine ended up getting water in it. Needless to say, we waited to long to do something to fix it and the engine had some rust in it when we tore it apart this spring. Sent in the cylinders to get bored and got new pistons for it.
Here is where the question comes in. We still have the cylinders off, but it seems like something is jamming the crank. I would assume that at this point we should be able to move each piston up and down by hand, but we have limited motion each way. Not sure if this is a crank problem or something jamming the shaft.
Can anyone shed some light on the situation here? Is it possible to have damage in the crankcase as well?
