95 HX wont go above 5000 RPMs
Dustin88
I was riding my 720 seadoo hx yesturday and all of a sudden it started to bog down above about 500RPMs. I runs great in the lower rpms but if you give it alot of gas it will bog down.
I just cleaned the carbs last month.
Just wondering if this is a common problem and could be computer related or if its a fuel problem.
could be fuel/delivery related but, try frst, disconnecting the red wire from rectifier, if that works, than replace the rectifier.
So I took the ski out today and it ran great for about 30mins then it started to stumble at high rpms so I unpluged the red wire from the rectifier and then It would start but would not rev very high and was really slow to accelerate.
Did it unplug the wrong wire or is that supposed to happen.
