Hello,
I have gone thorough the site trying to find a solution to stiff steering/bushing problem but did not find an answer if bushings are not replaceable ...
I have taken a 95 GTX out of storage (was not used for ~ 1.5 yrs) everything is up and running except the steering is very tight.
I confirmed the problem is in the steering head (steering cable disconnected at steering stem bracket holder -cable is free and smooth/nozzle moves easily). Based on reading here and a search online - my understanding that new bushings are no longer made for a pwc this old.
My Plan of attack to fix stiff steering:
- Pull out the steering stem and sand this down and lube/grease it up.
- Existing bushings - is there anything I can do to these? Try to remove w/o destroying?
OR Sand inside of bushings with 200 grit/400 grit paper?
Re-assemble and see if problem resolved.
Is the above good plan of attack? Any other recommendations for tackling this challenge would be greatly appreciated.
R/ Mark
R/ Mark
