I have a 95 GTX and the starter just clicks when I try to start. I have fully charged the battery and all it does is click. Any ideas. Last summer it would do this a couple times then turn over and start now it wont turn over.
take the jumper cables and go directly to the starter. If turns, then you know you got problem/s with ground cable, red cable from relay to starter or the rerlay itself...
First try to jump start from another battery. If you use a car battery, make sure vehicle is not running. i had the same problem on my 951 3 weeks ago.
I replaced battery, all good
