95 GTX Cooling Hose replacement
mfmeyer
Hello,
In replacing cooling/bilge hoses on second 95 GTX ski I am rebuilding (some deteriorating - some look to have been melted in spots). Almost all the hoses are the same 6mm clear type which i have on hand.
I noted the 6mm cooling hose from tuning pipe to exhaust cone is black and a different feel (looks/feels more like plastic) .
I found the part number 276 000 048 but wanted to know if there was a similar substitute I can pick up at auto/marine store?
I am surmising I cant use the same 6mm clear hose as in other areas do to higher heat content?
thanks for assistance.
r/
M Meyer
Since there is cooling water going though it... you can use the clear tube... but if for some reason you get low water flow... it will melt. I recommend a rubber hose of some kind in most of the connections, since it can take more heat.
