95 GTS Not Starting
stuarttgrant
I have a 95 GTS that has always given me starting problems. If I give it any gas or choke while starting it will not start. But if I hold the starter down for a while with no gas (for a while) or put starter fluid in the carborator it starts. After it runs for a while there is no problem restarting, but when it sits for a few hours the problem comes back. Any ideas on what this might be?
THANKS
Thanks!!!! Quick question:
Where is the best place to buy a compression tester?
If the compression is not right is this an easy adjustment or something the mechanic will have to do.
You can buy a cheap compression guage from harbor freight. It may not be very correct but it will be close enough to see if that is a problem. If the compression is to low you may have to rebuild the top end or buy a replacement engine. hopefully that is not your problem but you do need to know if it is ok. :cheers:
First thing...never use starting fluid to start you seadoo. It has no lubrication value. Use the oil you use to run in the seadoo now with some gas, so it is premixed. Add a small amoun in teh spark plugs holes if you need to. The compression test is to see if the engine needs some work done to it to repair it. Here is some information on doing a compression test.
You'll need a compression tester. Go to Auto Zone. I think they sell for like $25.00. The compression gage, will screw in the cylinder head in place of the spark plugs. To test compression, remove both spark plugs. Place spark plug caps on the plug cap studs near the cylinder head to ground the empty caps. This completes the circuit of the ignition electrical system and prevents any electrical problems from the caps being un grounded. Using the correct adapter for the threaded end of the tester,( same length of the spark plug threads length)screw in the tester in one plug hole. Hold the throttle wide open. Push the start button. Watch the compression gauge, when it peaks out at the most compression, let go the start button. Read the psi number. I would do it 3 times to be sure it is accurate. Check both cylinders the same way. The ideal compression is 150 psi per cylinder. If it is less, it's not a problem as long as they are close to being the same. If the psi is less than 90 it might need be time for a tear down and a rebuild. If the psi in 1 cylinder is say 140 psi and the other is 80 psi you need to tear down and repair. This difference is a lot and there is a problem. I hope this helps you.
If the compression test is good then it could be dirty carbs too.
It sounds like you need to remove the carburetors and clean them. If you're careful and don't tear or damage the diaphragms you won't need to buy a rebuild kit. Pay attention to the internal filters too. If you have gray fuel lines you need to replace them with black fuel lines available from auto parts stores like Auto Zone. Measure the length you need and bring a sample with you so you get the correct size. Replace one at a time so you don’t get them mixed up. If you need clamps replace them too. Use small stainless steel clamps also from the auto parts store.
Karl
