david reed
the fuel line check valve at hull lineis plugged would this be the cause of stalls after 5 min then restarts with choke then runs less and less till forget it vapor lock type symtoms i have changed fuel lines cleaned filters and cleaned carbs is it safe to bypass also bypassed on off reserve valve
