DaveWorden
I'm sort of new to the PWC world so i apologize if this is a common overpost - needed to replace the wear ring on my ski, the pump housing was corroded and stuck as most are and ended up being destroyed in the process of removing it. I've got the newer plastic 140mm housing as the aluminum housings are now discontinued and i am looking for the longer studs to accommodate this housing. If anyone could shed some light on where i might be able to find these longer studs and if the existing studs are threaded into the hull or basically embedded when it was made i would really appreciate it, thanks!!
