94 xp 650 oil pump prime
there is a bleed screw on the injection pump under your carbs. Open it untill oil comes out smooth, and tighten it back up, Your Done.
Here is a little extra information on the oil pump cables that is an important step also like bleeding the pump. First you need to adjust the carburetor idle so the speed adjust touches the adjustment plate. Turn the screw 2 more turns. Turn the cable adjustment screw to align the marks on the Injector pump. Look closely and you’ll see the marks on the cable disk and the pump. Use a mirror if necessary. The throttle and oil injector must be synchronized to react at the same time. This adjustment is the same on single or dual carb models. Be sure the oil is in the lines to the carburetors. (Use a helper in the next step) Start up the seadoo on the garden hose, be sure it is running before you turn on the water. Push the cable disk( pump lever) to full oil while the seadoo is on the water hose. DON”T REV THE ENGINE, let it idle, while you getting the oil to the carburetor hoses. Turn off the water and shut down the engine. Recheck the adjustment of the cables.
Karl
