I'm Working on my friends 94 Speedster. I have a repair manual that is somewhat helpful, but i am unable to determine if i have found the problem or not. Here goes: the starboard motor runs and revs fine. the port motor has no spark, everything else checks out. When you go to start the port motor the moment you hit the start button, the 5 Amp MPEM supply fuse blows. i totally disconnected the magneto/stator from the (ignition module?) deal betwen the coils at the bottom of the electrical box. Still blows the fuse. then i switched the (ignition Module?) deals around and the problem remains? When the beeper deal is connected, even when its absolutley cold it countinuosly beeps, until you ground the over heat sensor wire on the starboard motor, or until you take off the wire from the port motor, it buzzes when its on and when its grounded. I think it's a problem in the MPEM but at the same time i'm pretty much lost at this point, any help would be much appreciated.
