jpeters311
I have 2-1994 seadoo sp skis and one seems to have run fine, and pushed fine since i bought them. I bought them memorial day weekend of this year (2012). The other however every time i have taken it out seems to not want to get up to plane. Well let me start from the beginning. The one with issues when i got it would almost not even get up on plane, or not for a long time, and every time it came out of the water over waves it like completely lost propulsion and had to start all over again. It also made an obviously different "pop" noise every time it came out of the water. I took the pump off and noticed the aluminum prop was in horrible shape, and the venturi was chipped in 3 of the finns pretty deep. So i went to my local salvage shop and bought a used entire pump assembly which came with an oem stainless prop. I just changed the pump oil and slapped her on. The neoprene seal was in good shape yet, so i used it. Greased them both up and took them out. Seemed to totally fix everything for the first 30 minutes, but then it seemed to start wanting to cavitate or loose propulsion every time it got a little rough, easier than the other one i have anyway. So i was looking on this site and maybe thought that the seal carrier was worn out. This doesn't have a carbon seal either remember. So i bought a repair kit from sbc which actually was the carrier and all as a whole unit. and while i was at it decided to replace the wear ring and rebuild the pump so it would be like "brand new". well after doing all that, the pump whines really bad when running. pretty sure it may just be my bearing job i did. I don't know if i bent a bearing putting them in or what i could have done. Maybe would it be the thrust washer/bearing making the whining noise? And on top of all of it, it still seems to loose propulsion in rougher water, again not as bad at first, but the longer we rode the worse it got. When i changed the bearing carrier, the shaft seemed to have grease on it that was "sucked" from the carrier and stuck onto the shaft just behind the carrier which would be underwater.
On top of all of this. I decided to put new plugs in both skis. There were BR8ES plugs in both, but i read online many places to use BR7ES plugs. So that's what i did. They both ran great for, probably 2 or 3 hours. Then they started to seem like they were bogging down a bit more. So id just try and open em up good to clean them out, which wasn't working. one starting running so crappy we just towed it back because it wouldn't run but only at an idle. The other started to run crappy on our way back and by the time we got to the channel, no wake area it ran fine at the idle, but then naturally about 200' from the dock, it shut off. It would not fire at all after that, and i pretty much rode the starter in bursts to the dock. luckily no wind or anything so it was fine. i didn't have time to pull the plugs to see what kind of shape they are in yet. but does anyone know any inside facts about the skis and plugs? or what i should look at? also i need to change my fuel lines yet. they both have the grey lines... im trying to get them up to speed one thing at a time though... I run premium gas in them...
any suggestions would be appreciated!
Thanks
sorry for the novel.
Thanks
