Hey everyone!
I'm new here and new to Sea-doo's. This year I bought a pair one was suppose to run the other was in the process of being repaired. The one that runs does, just dogs out on the high end. It just started that. I am thinking it may have sucked in something in the carbs and just needs to be run more.
The other one
I think has some real issues. I got it all put together and put some oil in the cylinders and turned it over by hand a few times then let it sit over night. The next day I turned it over with the battery-plugs out. Next I assembled and tried to start it after a few tries it started and run ok and smoked a lot after a few (30) seconds I shut it off. I was not concerned about the smoke there so I took it to the lake and put is in and it run for several minutes (with lots of smoke still) then died. each time it would start,but would run less time, till it would not start. We put it back on the trailer and rode the other one. after we come back, the one on the trailer started. Once I got it home I gave it the one over checking for anything loose and water logged, it still started. The next weekend, put it back on the water, it ran a little longer and died, It never would stat again. Got it home and pulled out the plugs and they were wet and black ( these were new plugs). So this weekend, I got it started in the dry and it run ok, I hooked a hose to it and it run and had a dark gray smoke with a fair amount of oil in it. What run out on the ground was black. after a few minutes it began to die. Once it died it did the same thing run less till it would not start.
I am operating under a few ideas, but I dont know enough to prove any of them right or wrong.
Could it be drawing water into the cylinder?
Oil injector issue?
Carbs not adjusted correctly? Jets stuck open and just flooding it?
I don't know if the water is an issue or not. I would hate to run it long enough in the dry to dry to prove it.
I do have a shop manual, but I am not thriller with it because it covers all the models and has some generic stuff for them all and not the specific stuff for just the XP.
So now that I have written a book about it. Does anyone have some good info about it?
in the FYI column, I have put the Seadoo oil in it.
Any help will be very much appreciated.
Cjammer.
The other one
Oil injector issue?
Cjammer.
