94 sea doo sp 580
david reed
runs great on lift will just die udur power after 5 minutes or so but restart with choke thought it was electrical something loose eliminated kill switch seems to get progreesively worse as you keep restarting till start stop startstop recalled and replace tank im thinking ignition coil but seems starved for gas vapor lock gas lines help
Fuel lines and carb?
What color are the fuel lines and when was the last carb overhaul?:cheers:
yes im reading the factory grey lines seem to be a problem do they collapse or suck air im not seeing any gas leaks but sounds like ishould start there and move to carbs are they similar to snowmobile reprime oil injection before restart
