Hi everyone, thanks for the motivation, I have these issue going on, with 1 of my (2) 94 gtxs, it was last registered in 07 to alabama, I bought here in az from a female teacher if that matters..both had oil pump canceled, one had cover plate wer pump goes the other im working on, just had gear removed, when i bought it would only turn over with spark plugs off, turned on once even, sparks were rare here and there, I did the shortening of the cables, cleaned every connection with a small file, while i waited for my ebay starter to arrive along with solenoid, also cleaned carbs..they got here, hooked everyhting up, good sparks, it shocked me hard, but starter just clicks, i found a lost volt tester and used to check battery.. fully charged as i keep it that way,+ red on battery, - on engine it reads full.....- on battery & +red at the end of + cable it reads full, even on the other side of solenoid when hitting start button, as soon as i connect + cable at solenoid to the starter the voltage just drops to about 3, when tryn 2 start,I hooked up starter directly with jumper cables.and it seems to push flywheel with force before i get weld marks from battery cables, I cant really imitate solenoids function lol... any advice..Thanks
