Martin42
Hello, I would like to fix the VTS on my 1993 Sea Doo XP. Throughout a series of tests, I’ve concluded my relay(s) are bad. I had the ECU opened up and the one side looks to be dedicated to the VTS circuit.
The problem is the whole board is in an epoxy which makes changing the relays a Very difficult but not impossible task. What I need to know is if there is any secondary source of power running through that board because If something was to go wrong, would the seadoo still work? I don’t want to affect any other components to compromise the workings of the machine.
Is it possible it find a schematic for that module so I could rewire the relays without digging the existing ones out?
Any help is appreciated, thank you!
