93 GTX hi pitch squeal
Bricknjman
I was out on my 93 GTX and after about an hour I felt a hesitation then started hearing a high pitched squeal from the rear somewhere. I was able to ride back real low speed the noise went away but the second I get to like 1/4 throtle it would come back. Any ideas? Thanks!!!!
Sounds like your pump is getting ready to lock up. For a quick check pull the spark plugs and try turning the engine over by hand. You can remove the PTO cover and grab it to turn the motor over. It should move reletivly easy. if it doesn't pull the pump and try it again.
Thanks!!!
Is there any cheap way out for this? How hard is it to rebuild and does any one have a rebuild kit for this?
Thanks again
You can go to the seadoo forum "parts" site for parts needed. I would figure out what you need first. Do you have a seadoo shop manual? If not here’s an idea for you. You could join as a "premium member". As a premium member you can down load a authentic seadoo manual from the seadoo manual library. In the library is a variety of manuals for almost all years and models. You can view as many as you like on line as a PDF file, or download it and print it for your personal and private use. There are operator manuals and repair manuals for you to do your own repairs on your seadoo. The repair manuals have everything from troubleshooting, repair procedures to winterizing. It contains wire diagrams torque specs and pictures for disassemble and assemble instructions. In the spec sheets it tells everything needed to maintain oil changes, spark plug gaps, carburetor rebuilds and impeller wear ring tolerances. Click on the "Seadoo Manuals" link at the top of the page for more details. If you need any help or get in a jam, we are always here to answer your questions too. Premium members get priority when it comes to getting quick detailed answers.
Karl
