I had the carbs rebuilt at a reputable shop over the winter and Im confident this is not a carb issue. The problem is When I start the ski on the stand, put water to the cooling system them give it some throttle it just goes flat like its starving for fuel. The fuel filter is new and clean. fuel line comes out of tank to shutoff/reserve lever then into the carbs on the mag side of the carb rack, crossover from front carb to rear carb is intact and return to tank comes out the shaft side of the carb rack.
The engine starts right up and sounds fine, compression is good and the spark is strong.
Any help on where to start with the diagnosis on this will be very helpful.
Thanks!
Thanks!
