93 Bombardier Engine Stopped Running
bobperson
93 Sea Doo Bombardier - Was running fine, smooth and then engine stopped. Can not restart. Checked plugs and could see good sparking. Held hand over open spark plug holes and felt compression during motor turnover. Appears not to be getting gas.
Questions: How can fuel pump be checked? Does it have a fuel pump? Can it be rebuilt? Is it difficult to change? What would a used replacement cost? Any other possible causes?
First I'd check the compression so you know what's going on inside. It sounds like the carbs need cleaning and if it has gray fuel lines they need to be changed also.
Here is some more information on the "premium membership";
As a premium member you can down load a authentic seadoo manual from the seadoo manual library. In the library is a variety of manuals for almost all years and models. You can view as many as you like on line as a PDF file, or download it and print it for your personal and private use. There are operator manuals and repair manuals for you to do your own repairs on your seadoo. The repair manuals have everything from troubleshooting, repair procedures to winterizing. It contains wire diagrams torque specs and pictures for disassemble and assemble instructions. In the spec sheets it tells everything needed to maintain oil changes, spark plug gaps, carburetor rebuilds and impeller wear ring tolerances. Click on the "Seadoo Manuals" link at the top of the page for more details. If you need any help or get in a jam, we are always here to answer your questions too. Premium members get priority when it comes to getting quick detailed answers.
Karl
Thanks. It does have compression but I will try to measure how much. I believe there is no fuel getting to the cylinders so I plan to remove and clean carburetor(s). Thought I would get more suggestions..
Thanks again for you assistance.
