I have located the leak in my 92 XP. A nice stream of water was flowing in from the hull fitting where the seal carrier hose clamp attached. I removed the jet pump to replace seals in seal carrier (I thought was the culprit). The bottom edge of the hull fitting was shot. There was a 1"+ crack around the bottom edge. I am trying to remove this hull fitting to replace it. It is not cooperating. As difficult as it is I am begining to wonder if this piece was not meant to be removed. It is pictured in all of the schematics as a piece of the drive system. I assumed (yea I know how you spell it ) it was a replaceable item. I can see the seam within the drive tunnel where it marries with the external most angled hull fitting. I have heated the hull fitting and gotten it to separate from the fiberglass in a few places as well as pretty much trashed it. Don't worry fire safety folks, I used a 2' long pipe and shot hot air to the piece from the top and from behind. How the heck do you remove this piece??? Am I on the right track??? Am I screwed???
