michdooer
I've got a 92' SP with no spark.
I had trouble with the battery after "trickle" off-season storage.
I placed it on a charger,..still had no "balls".
Tried to start the ski with a charger "start" mode...no dice.
The compression with the plugs IN was too much for the charger.
SO....
I replaced the battery & had a successful start.
Now spark went from having intermittant symtoms a few times to total no-go.
So far I've....
1. Checked the plugs with fresh ones (when this first occured)-same results.
2. Checked handle-bar "kill" switch - tested OK
3. Checked MPEM modual via Multi-Tester method- all readings within manual specks' by +/- 3 ohms. ("infinite" readings checked right-on.)
4. Checked Ignition coil last night.
FYI- I was measuring resistance btw the #1 & #2 spark plug cap area.
Am I measuring the "Secondary" Resistance wrong or what?
Readings from my Manual called for btw 9-15k for specs (if I recall correctly)
I had to switch my meter to 20000k setting just to see reading.
Does this coil look like a "wash" or what?
:banghead:
signed,
NOT DEALER -FEE READY YET!!!
SO....
So far I've....
:banghead:
signed,
